If anyone has ever lost tach operation in a Stude, after installing an ignition booster (i.e. MSD 6-AL), electronic ignition, or fuel injection, here's how to fix it: Install MSD-8920, "Tach Adapter".
Apparently, the 60s-70s vintage tachs require a stronger signal than the later ones. Most modern electronics provide a much weaker tach signal, that works great with early 80s and newer, but not with the older.
I lost tach operation on the 62GT two years ago upon installation of EFI, with ESC. The tach would work when cranking over, but the motor would not start. If the motor was already running, it would die when the tach was connected. I am one of those guys who likes to "drive off of the tach" so it has been painful living without it.
Recently, I read on the internet of several other folks with 60s-70s vintage vehicles, who had experienced the same problem after installing modern electronics. Most who fixed the problem did so with the MSD-8920. So I installed one on the GT a couple of days ago, and for the first time in two years the tach is working again !
Though some make it sound complicated, I believe the MSD-8920 is simply an amplifier. It draws only a little juice from the negative side of the coil, just as a modern tach does, then amplifies it to a signal strong enough to operate the older tach.
It took me two years to get the tach back in operation, so just thought I'd pass it on, in case someone else is suffering without their tach, as I was.
