What is the recommended today lube for a T86 W/OD ?
What lube should be used in T86 w/OD
Tags: None
There are numerous posts here about the Manual Trans. needing NON-extreme pressure EP additive approx. 90Wt. Mineral Gear Oil.
It must be GL1 80W-90 or straight 90. NAPA and Farm Equipment/Supply Stores have it in Gallons. If not Order it.
Your Standard on the shelf Rear Axle, Hypoid Gear Oil is GL4 or GL5 (EP) fine for Rear Axles, but NOT Transmissions.StudeRich
I've been using Amsoil synthetic 75W-90 manual transmission oil in both 3 speed and 4 speed Studebaker transmissions for the past few years and I'm really happy with the results. The oil is specifically formulated to be used in manual transmissions with yellow metal parts in them and should not be used where an extreme pressure lubricant is recommended such as differentials. Bud
The 40 wt.engine oil for the transmission should also be NON-additive, straight mineral. It is available at small airports that have an FBO (service facility for light aircrasuch as single engine personal craft). It must be specified when purchasing since they carry several different types of engine oil. The oil i obtained was Shell Aero - However, other brands will also be available depending on the dealer (usually they sell only one brand of oil, fuel, etc.) it is a bit pricey at about $6.00 a quart, but only a pint or so is needed, so it is enough for about two refills.
Paul TK
