A couple of years ago I installed a Turner front disc brake kit with dual MC in a 60 Champ PU. Since then brakes have never been good, really kind of scary and I am trying to find out why.
Maybe some one here that has done the same conversion has some insight? (I've e-mailed and left Jim phone message - haven't heard back from him)
We have and are still having a soft pedal over all and the fluid seems to be bleeding back into the MC as we have to double pump on the first braking action when going down the road. We do seem to have good brakes but soft pedal and double pump. I have ordered new in line residual valves and will install them but right now we have taken the original ones made by wilwood out of the system to see if we could tell any difference but have noticed none. We have bled the system after each change was made and then some more. No air coming out, just fluid. Using Dot 4 brake fluid.
We put new shoes, brake pads, flex lines and replaced the original MC in the kit with a new one,Raybestos MC36237-74 (One application that this mc fits -AMC Ambassador power front disc/rear drum) and took out the valves, checked the residual in line valves-10lb rear and 2lb front. I pulled the cab brace off by drilling the spot welds on the cab portion out so we could better judge the action of the pedal and rod assembly into the MC. I wound up building a different connection pin out from the pedal assembly to give the "into" mc rod a much better angle to go into the MC. All that checks out now. I checked the rod distance into the mc piston and that seems ok - makes contact with the piston inside dished area. There seems to be a very small distance for adjusting, a smidge too much and the front disc's lock up, a smidge the other way and very little pedal- to the floor.
At this point I am wondering if the dual chamber mc in the kit is properly sized for the PU brake system and if that is the root of the problem?
