I've set up a brake system for a 63 Avanti, using Turner front Disc/and a Ford 8.8 rear end and the ford drum wheel cylinders. This has a 75 Camaro
MC and a Wilwood proportioning valve set-up. The MC has new lines/fittings. The bleeder valves were removed and air put to the system to clear all line
restrictions. The problem, I cannot bleed the system, I can't get brake fluid to flow. Called Wilwood two times for answers! I've used a Motive bleeder
tank, to find leaks in the fittings. Everything seems ready to go tomorrow but, has anybody had a similar problem and found a solution. Thanks for your
help and all ideas, suggestions. This has now been several days and I have not found a solution.
