I need a driveshaft for my 1957 Packard wagon. 1957 Studebaker wagon is the same. It's a two piece shaft with a center support bearing. Front shaft is roughly 22 inches and rear shaft is 39 inches. S/P part number for front shaft is 1541749, support number is 532009, rear shaft is 1541597. Any good used shafts are fine, will be replacing universal joints anyway. Any leads will be appreciated!
Anyone Have A Spare Driveshaft?
Lt. Col. Jimmy Doolittle
"I have a great memory for forgetting things" Number 1 son, Lee ChanTags: None
I was at Roy Hastings' place recently. He had several driveshafts stored away. Not sure what they fit. Contact Bob Edwards @ www.studebakernef.comNeil Thornton
Not to hi-jack the thread, but I'm also looking for one for my 4-Speed Daytona...Tom - Bradenton, FL
Originally posted by 50pete View Posti have a complete 2 piece from a 50 champion 2dr sedan. i'll measure it tomorrow, unless someone here can tell us if it'll work............StudeRich
I'm pretty sure I have one on a '57 wagon. It had a 3-spd manual OD on a 259 V8. Don't know the condition as the car sat in a field for many years. Everything else though has proved to be pretty good from this wagon. So, I'll look when I get back to Fawn Lodge if you like.Home of the famous Mr. Ed!
Ron Smith
Originally posted by studeclunker View PostI'm pretty sure I have one on a '57 wagon. It had a 3-spd manual OD on a 259 V8. Don't know the condition as the car sat in a field for many years. Everything else though has proved to be pretty good from this wagon. So, I'll look when I get back to Fawn Lodge if you like.
Billsigpic1957 Packard Clipper Country Sedan
For '57 sedans/wagons the V8 rear shafts are basically the same until you get into Y bodied cars.
The front shaft lengths get goofy because of the different transmissions.
The best bet is to check the book really close and compare for yourself.
You might be surprised at the commonality between Champions, Commanders, Presidents and Packards.
Bill- if your Packard is a stick- Roy's option should be a match. I'd double check the book to be certain.
I'd also be sure that it gets marked when it's pulled so the reinstallation is 'clocked' properly.
Ask me who I know about this...
Originally posted by rockinhawk View PostI was at Roy Hastings' place recently. He had several driveshafts stored away.
StudeDave '57
Originally posted by StudeDave57 View PostFor '57 sedans/wagons the V8 rear shafts are basically the same until you get into Y bodied cars.
Neil, please tell me that does not mean what I think it means.
StudeDave '57Neil Thornton
I have one from a '53 Commander C/K automatic; two piece.Brad Johnson,
'56 Sky Hawk in process
Originally posted by studeclunker View PostWell Dave, when you come north next, perhaps you can show me what is meant by "Clocked".
I'll wait on removing the shaft for your arrival.Originally posted by rockinhawk View PostDave, I don't know if you know about Roy's condition but the prognosis is not good.
Send me a PM and I'll fill you in. I don't want to put it all here.
StudeDave '57
