I've installed a new master cylinder and brake booster and the correct linkages and rods from Myers. New brake lines and hoses. Even added Turner Disc Brake package.
With the vacuum connected to the booster. I can feel the assist when the peddle depressed (really stiff) then start the engine, the peddle pulls in more.
I've manually bench bled the master. Added brake fluid. Successfully beld the Turner Disk front, leaving the rears. Can't seem to get fuild to the rears.
I unthreaded the rear circuit from the master and have a proportioning valve in the Master cylinder.
Do I remove this valve to bled the rears?
Allen
Allen
