Replaced the am radio in a 1963 GT Hawk with newer FM after market radios. After I start the car, the radio will cut out for about a half second. Tried 3 different FM radios. All do the same.Thought it was a ground issue. Ran separate ground and hot wire to the battery. Same problem. Then ran the negative to the frame. Same problem. Ready to give up. All radios run fine if not hooked up to the Hawk. Ready to give up. Ideas?
Stude Steve
Stude Steve
