There were a limited number of CalTrac traction devices made, by a member of the forum. I am starting a registry of those who purchased them. Please let me know who you are, and the description of the car you installed them on, and the results you had at the Drag Strip, in terms of reduction of Elapsed Time. This will be very helpful to me, and everyone else, especially those with cars that have 365hp chevy engines, like the one Dick Steinkamp had. In spite of having 365 hp, with Ted Harbit at the wheel, Dick's car could only run about 14.9-something. Did he put some CalTracs on, and do better? How about Bams--what has he done with his CalTracs? Please--I cannot accept anecdotal evidence(aka, BS), I need verifiable results. Thanks.
Cal-Trac Setups...
You're not a lawyer are you????Bez Auto Alchemy
Originally posted by Reggie View PostThere were a limited number of CalTrac traction devices made, by a member of the forum. I am starting a registry of those who purchased them. Please let me know who you are, and the description of the car you installed them on, and the results you had at the Drag Strip, in terms of reduction of Elapsed Time. This will be very helpful to me, and everyone else, especially those with cars that have 365hp chevy engines, like the one Dick Steinkamp had. In spite of having 365 hp, with Ted Harbit at the wheel, Dick's car could only run about 14.9-something. Did he put some CalTracs on, and do better? How about Bams--what has he done with his CalTracs? Please--I cannot accept anecdotal evidence(aka, BS), I need verifiable results. Thanks.
I don't remember things very well any more but I do not recall ever driving Dick's car. ??
Ted
Has the patent run out on the Caltrac's traction bars? I think their patent is 20 years old.
Even if it is, you can still build your own. Just don't try to sell any.
Jerry Forrester
Forrester's Chrome
Douglasville, Georgia
Yes, that looks like it would be fairly easy for the accomplished DIY. I had run across that design, and wondered if anyone had used them yet, and how streetable they are insofar as noise or harsh ride, etc. That is what I was researching. But, I guess I'll just build a set for my own use, and try em out. It will be easy to reverse the modification, if they don't work.
Originally posted by Jerry Forrester View PostHas the patent run out on the Caltrac's traction bars?
A traction device is provided that includes a rigid front mount assembly that may be clamped to or around the vehicle's leaf spring, thereby creating a positive displacement point for torque transmitted from the rear axle through a telescoping linkage. An advantageous shock absorption element associated with the telescoping linkage cushions forces transmitted therethrough. Free travel and pre-load adjustments are made quick and easy through a readily accessible adjustment mechanism. A preferred bracket design is also provided which ensures optimal force transmission and enhanced system strength and reliability. The traction device of the present disclosure may be included in original vehicle fabrication and assembly, or may be readily installed on existing vehicles without the need for welding or modifications to the chassis or rear axle housing.
But that doesn't look anything Caltrac's original design.
Originally posted by 61Lark View PostDoesn't look like it.
https://www.google.com/patents/US638...ed=0CDwQ6AEwAQJerry Forrester
Forrester's Chrome
From the early/mid 70's & forward loads of Swedish drag-racers, even street-racers, had those & I don't know if they bother buying them or making it yourself but they were always yellow-painted.
So what's the interest in this...? Really?
I can hardly imagen they were that un-usuall in the States if they were all over the country in Sweden...
(I sure wished I had spring-leafs AND THAT on my -64 Chevelle SS (with more done to the 327 than I can remember) in -79 but coil-springs... BAH! )
Originally posted by Jerry Forrester View PostHas the patent run out on the Caltrac's traction bars? I think their patent is 20 years old.
http://www.hotrodsandhemis.com/Traction.html
The first patent on this design was filed by M Valerio in 1976 https://www.google.com/patents/US4098523
John Calvert, of Cal-Trac, filed a patent in 1993 https://www.google.com/patents/US5354092 claiming an "Improvement" over Valerio's design
Michael W. Kugler, of Moroso Performance filed a patent in 2000, https://www.google.com/patents/US6386565, claiming an "Improvement" over Valerio and Calvert's design
The design in http://www.hotrodsandhemis.com/Traction.html[/QUOTE] resembles Calvert's design, not Kugler's..
It would be interesting to see when the description in the hot rod's link was first published, as to note prior art, voiding Calvert's patent.
Calvert's design was issued patent on Oct 11, 1994 which will be 20 years this October..
