Just was wondering if it was in the place like turbo 400's ? Mine is a detroit gear 250 and the dip stick is in the floorboard .
Where was the dip stick on the flightomatic? vs. detroit gear 250
The flightomatics that I am familiar with have the dipstick in, and acting as the cap for, a 3/4 inch thick fill tube coming up along the right side of the engine.
That tube begins with a BIG gland nut at the rear of the transmission oil pan, makes a 180 degree turn, and heads up the side of the engine.
The dipstick under the hood is found on 61 & later cars. Before that there is an inspection plate on the right side of the transmission tunnel in front of the passengers front seat. Under that plate is the cap that holds the dipstick. I would think it is the same on the D.G. transmissions too but am not familiar with those so let the more knowledgeable ones chime in on that.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
Hello,
On the D.G. transmission installed on my 51' Land Cruiser, there is a cap located on transmission tunnel as Warren said. Under the cap is where you can pull the dipstick.
Originally posted by Warren Webb View PostThe dipstick under the hood is found on 61 & later cars. Before that there is an inspection plate on the right side of the transmission tunnel in front of the passengers front seat. Under that plate is the cap that holds the dipstick. I would think it is the same on the D.G. transmissions too but am not familiar with those so let the more knowledgeable ones chime in on that.
Yup. DG is on the tunnel, under the cap. Fluid must be checked while the tranny is warm and the car is in gear or fluid flies all over. It's hot and sticky.Dave Warren (Perry Mason by day, Perry Como by night)
Originally posted by SilverHawkDan View PostYou can put the late model pan and dipstick on an earlier trans and just not use the floorboard one. Been there and done that just for the reasons Dave Warren said. Parts were available through Stude parts dealers a recent as a few years ago. Dan
Since you have a Detroit Gear DG250, you can not.
