I understand from an ex-Studebaker mechanic that the best way to start up a motor that has been sitting for a while (but still free)is to disconnect the coil wire. Then use the starter to build up pressure. Re-connect the coil wire and start it.
Apparently, damage is done when an engine turns fast (i.e. starts) and there is no oil in circulation, but no damage is done upon the slower starter speed turnover.
I also have heard about taking out the distributor and using a drill in the oil pump slot to get the oil in circulation. (V8 only.)
Any comments?
Paul R
Any comments?
Paul R
