I've been working away on the final details of the spring mounts and shackles for my Indy car replica and I started focusing on how much weight/force was transferred from the springs to the frame at various points. So, the front leaf spring eye has a bolt through it that secures it to the front end of the frame. The rear eye of the leaf spring is bolted through the lower end of the shackle. The upper end of the shackle is bolted through the frame so that the shackle can pivot freely. But, I'm thinking, if the shackle can pivot, it can't transfer any upward force to the frame, so all the weight and bump forces must be transmitted through the front spring eye.
I had always made the simple assumption that the half the weight of the car was supported through the front eye and half through the rear eye, but that doesn't seem to be the case. As the car hits a bump, the spring flattens, so the shackle must pull on the bolt through the frame, but it still isn't supporting any weight. This doesn't make sense to me. What am I missing?
