I have a fiberglass hood mounted on my 1959 Silver Hawk - as a rear opening hood - and I need some reinforcement at the back of the hood. Clearances are pretty tight there, but I noticed that the original steel hood has a reinforcing structure that would fit and obviously has the correct curvature. Here is a longshot: Does anyone have just the underhood reinforcing structure - the one at the rear of the hood with the hood hinge mounting bolts on each end - that they have removed from a C/K hood? Thanks.
C/K hood reinforcement
Why not fiberglass a reinforcement in? Use some styrofoam strips, and then fiberglass over them, this will create a "channel" that will stiffen the area you need. I did that on an Avanti nose panel that was too thin years ago. It's still holding up. You could also use cardboard strips.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
Originally posted by warrlaw1 View PostMight not be appropriate for FG, but I used the hood stiffenesr from Classic Enterprises on my original hood. Check their website and see if it would help.
Originally posted by 52 Ragtop View PostWhy not fiberglass a reinforcement in? Use some styrofoam strips, and then fiberglass over them, this will create a "channel" that will stiffen the area you need. I did that on an Avanti nose panel that was too thin years ago. It's still holding up. You could also use cardboard strips.
Jim
Originally posted by 3x2stude View PostTom,
What brand is the hood? Is it a pin-on or hinged? Here is what I have, race weight but hinged.
JK
[ATTACH=CONFIG]33070[/ATTACH][ATTACH=CONFIG]33071[/ATTACH][ATTACH=CONFIG]33072[/ATTACH]
