Can the 64 hardtop door be used on the 64 Commander 2 dr. sedan. I understand the top steel portion of the Commander 2 dr. door unbolts and can be installed into the frame base of the hardtop door. S.I. does not have the Commander door but has the hardtop door. My door has a bad kink from opening wrong and has to be replaced. The outer skin is not available.
Also need the part number for the right (passenger side) sheet metal that holds the headlight bucket and connects between the radiator framing support and the inner fender apron. I think it is #1356000 but the S.I. books calls it an air deflector. If you have the part number for the inner right apron that would help. I believe it is #1356084 per page 146 of the S.I. book but not sure. Thanks.
