Sometimes I don't think I will ever get this car drivable. Two steps forward and one back, or in my case it could be the other way around.
I am almost ready to paint.
Now it won't start.
I can use starter fluid and it fires up for a couple seconds.
I disconnected the fuel line and used a can with new gas. No luck.
I thought a fuel pump so I bought an electric fuel pump. Same issue.
When I disconnect the line I get a little pressure pop.
I can use starter fluid to start it and then give it a little squirt and it will run until I stop.
I banged around the float area still no luck.
I bought the car with two carbs. I had the one that is on it rebuilt over a year ago. It worked great until it didn't. I put the old carb back on same issue.
It has an electronic ignition. So no resistor or capicator... or so I think.
I am so close to just giving up and selling the car.
I appreciate any ideas.
Now it won't start.
