The Delco window distributor in my car has a frozen advance plate, i.e. the advance plate will not move. My question is whether I can replace the advance plate with one from a GM Delco window distributor? Has anyone done that? Thanks.
Delco Window Distributor Advance Plate
Originally posted by GinettaG12P View PostThe Delco window distributor in my car has a frozen advance plate, i.e. the advance plate will not move. My question is whether I can replace the advance plate with one from a GM Delco window distributor? Has anyone done that? Thanks.
I'm confused, are you talking about the breaker plate or the centrifugal advance mechanism at the top of the distributor shaft? If the centrifugal advance is stuck, you can use either a good penetrating oil or carburetor cleaner to free up the solidified grease on the distributor shaft. It's very rare to have the breaker plate stick unless it has been subjected to excessive moisture for an extended period. The breaker plate from a Buick, Olds or Cadillac will work in a Studebaker distributor, but the distributor cam should be from another Studebaker distributor. Bud
The plate that is frozen is the one that the vacuum advance moves (only mine doesn't move.) I've tried penetrating oil, 50/50 mix of ARF and acetone, WD40, etc. but I can't get the vacuum advance plate to move freely. So, my question is: will the vacuum advance plate from an early Chevy window distributor fit my Studebaker Delco window distributor?
Yes they will interchange just fine.Bez Auto Alchemy
Originally posted by GinettaG12P View PostOK, I just bought a 1955 Chevy 265 distributor for parts.
Studebaker also used non window Delco distributors. The window appeared in 60-61. Not sure when Chevy changed to window type. The differences are minute between Chevy and Studebaker other than the housings.(on window types).
The amount of advance and rates were different.Bez Auto Alchemy
The breaker plate from a Chevrolet especially one from a 55 or 56 265 Chevrolet since they are the earlier type distributor will not work in a Studebaker distributor along with any later Chevy window distributor as the advance works in the opposite direction from the Studebaker distributors. As I stated in an earlier post, a breaker plate from a Cadillac, Olds or Buick will work in a Studebaker distributor. Bud
I was thinking of the advance plates, not the breaker plate. The rotation doesn't affect the advance. Of course the BREAKER plate will be different with different directions of rotations. For one thing the rubbing block wont retain lube. All of this wont matter, and you CAN use a Chevy breaker plate if you use electronic breakerless conversions.Bez Auto Alchemy
Originally posted by GinettaG12P View PostHi Bob,
The distributor was an early window distributor (with the oiling tube) that was described as fitting a 1955-60 256, 283, 327 (although 327 didn't come out until later.) There were a bunch of photos of it, so it looks like the right one.
Tom
BTW: Cadillac and Oldsmobile got window distributors for 1956.
Chevrolet, Buick, and Pontiac got them for 1957. BP
Working on a Delco distributor for my 62 Champ. I got a new vacuum advance with the proper # & installed it. Trouble now is the breaker plate doesn't want to move. When I tighten the screw that also holds the ground wire, it binds right up. Loosen it & I can move the breaker plate but its still hard. I cant imagine vacuum from the advance can would be able to move it even then. Suggestions???59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
Is the screw too long, Warren, and hitting something underneath when you tighten it fully?
The return spring in the advance can be stiff and might fool you into thinking the plate can't revolve. Does the plate move freely before you install the new vacuum advance? If it does not, you need to remove the advance plate and clean and lubricate everything. It should be very easy to move without the advance attached, and will be much more difficult to move by hand with the advance in place.
Once you think everything is OK, connect a length of vacuum hose to the advance unit and try sucking it. You should be able to pull the advance to full advance and then watch it pop back when you release the suction. BPWe've got to quit saying, "How stupid can you be?" Too many people are taking it as a challenge.
