Hello All,
Description:
I am going to cut to the chase. About three weeks ago, I put a new 6 volt battery into my 1951 Studebaker Land Cruiser that I am restoring. I was able to get the engine to turn over and briefly start. The vehicle briefly starting and then dying is a whole different topic that I will address at a later time. About a week ago, I notice that when I tried to start the car up the starter was rotating very slowly as if the battery was dying. I went ahead and checked the battery with a volt meter and received a reading of 6.37 volts. I then went ahead and charged the battery to where I was receiving a voltage of about 6.70 volts. I then proceeded to try to turn over the engine again and yet the starter was turning the engine slowly. I then figured that the car had been sitting for some time and that the starter had to be rebuilt. Fast forward to this weekend. I rebuilt the starter, cleaned the terminals on both battery cables, starter solenoid, and the cable going from the solenoid to the starter. I was not impressed when after doing all of that, that I was still having the same problem. Now before I start replacing every single component in the engine compartment (which I probably will eventually) I would like to know what could be the next possible culprit. I was thinking it might be the starter solenoid, but I am not having luck finding an affordable NOS one to gamble on.
Summary:
Specifications: 1951 Studebaker Land Cruiser, 232 V-8, Automatic, 6 Volt system.
Problem: Starter turns slowly as if I have a dead battery, but battery is fully charged.
Things done so far: Charged battery, rebuilt starter, cleaned and secured battery/starter cables, ensured
ground connection is clean.
Next possibility: Starter solenoid?????
Questions: What is the culprit?
Does anyone have a NOS solenoid?
Thank you,
Brian
Description:
Summary:
Thank you,
Brian
