I need a single groove water pump pulley. It needs to be between 6 1/4" to 6 5/8 in diameter. The backspcing (distance from back side to flange mount surface) 1 7/8 to 2". Maybe a A/c one or other. Thanks, Tex
Water Pump pulley needed
I have a fan pulley with a stamped part no. 3995646AH - no idea what it is off, maybe Valiant or AMC. It is a stamped steel dual belt pulley with a diameter of 5.75" and back spacing of 2.5". If the rear belt run is trimmed off on a lathe, then you have a back spacing of 2". That however puts you into an "overdrive" situation. Discovered I had it while checking pulleys.
