Where can an automatic transmission shop manual be obtained (or can it) for a 1954 Commander (hard top), DG200 #SCO259091? I assume that's the correct tranny. The tranny is mechanically fine but it needs all new gaskets so as to stop an annoying drip. The 53 shop manual says to see separate manual for commander automatic tranny. Also trying to locate correct head light switch, present one works but it has to be giggled to turn on lights. Ken, Deltaville, Va
54 commander tranny manual question
It's covered in both the Shop Manual and the Chassis Parts catalogue. Also the Studebaker International Catalogue has great illustrations. I'm running a DG200 in my 55 Commander hardtop. You'll find switches in the S.I. catalogue, too. Good luck.Dave Warren (Perry Mason by day, Perry Como by night)
You can also disassemble the light switch, clean it up with WD-40 and a brass brush, grease it with silicone grease and reassemble it.
A perfect CASO solution, and it works.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
The Detroit Gear DG Series Transmission Shop Manual Supplement is out there, they show up at Literature Vendors' Websites and at Swap Meets, but I believe the '53-'54 Shop Manual 800421 includes it.StudeRich
Originally posted by Dwain G. View Post
Originally posted by ken-renda View PostThanks for information. Does the 56 shop manual (covers my 56 and 57 GH) contain the same thing? if not will order manual specific to DG 200?Gary L.
Originally posted by ken-renda View PostThanks for information. Does the 56 shop manual (covers my 56 and 57 GH) contain the same thing? if not will order manual specific to DG 200? Also when DG-200 was removed from engine a part fell out from the front shaft, see picture. Is it back in its proper position? Will take tranny to mechanic and want to make sure part is in the correct position. He's a modern day Ford tranny guy who says he enjoys working on these "mechanical" parts but he needs appropriate manuals. Ken, Deltaville Va
The part that fell out is an fluid distribution tube. Just push it back in until it stops. Sometimes these stay in the torque converter, need to be removed and put back in the trans. main shaft.Restorations by Skip Towne
Originally posted by Dwain G. View PostNo, the '56 shop manual mentions it, but refers you to the Auto. Drive manual.
