Last year when I installed a 700R transmission in my 54 Commander the new starter that came with the trans required 12 volts neg ground. So I did a partial conversion. I am now finding out that was a mistake. The starting system is 12v
neg ground and the cooling fans are also 12v. The rest of the car is 6v neg ground. The 6/12 battery does not seem to hold a charge for a more than a week and I have verified that the new alternator is putting out 13.8volts. I am thinking of converting the rest of the car to 12 volts and put in a big Optima battery like I have in my other classics and be done with it.
Question is the ignition system is a 6 volt Pertronix coil but am still using points so the coil will have to be changed. The lamps will have to be changed and a dropping resistor will have to be put on the radio. The oil gauge does not care and I don't think the amp meter cares as the current will be reduced . Do the fuel and temp gauge have to be changed or will a dropping resistor work on them? What else am I missing? Turn indicator flasher and horns? Also I live near a classic speedometer place that restores old gauges and they can do a 12v conversion. That may be a good option
Thoughts and input is appreciated.
Thanks,
Mark
Thanks,
Mark
