Ok I have had it with the single master cylinder, and it's leaks!
So no rebuild, no new...........better!
Going to a dual master cylinder.
Some questions: If I go the route of R5 fluid and I blow the lines out from the R3 fluid, what about the small residuum of fluid left in the front and rear wheel cylinders?
If I stay with R3 fluid, how soon do you think rust pitting in the cyl walls will commence with the resultant effect of rubber perforation/leaks?
