1953 Lombard Green color formula
  • 1953 Lombard Green color formula
    Hello,
    Does anyone out there know a modern mix formula for 1953 Lombard Green. I'd prefer a single stage enamel vs a base/clear. However, the base/clear might get me to the equivalent single stage.
    Regards,
    Charlie Kraynack
    Ask your paint supplier if they can do ~1971 Dodge truck "Pine Green #2". That is a nearly spot on match to '53 Lombard green and what I used for the roof of my car. I got this in Dupont Nason Pul-Cryl II acrylic enamel back in 200. Don' know if still available.
    Jeff in ND
      Thanks for the lead!
      Jeff,
      I will check my supplier and see if he can make a match. Any color photos of your car?
      Charlie
        Here's Jeff's car at Omaha...
        Bellingham, WA
          Jeff,...you've got one heckuva long memory!!!
          Hey, Charles! One of my best friends was born and raised in Tunkhannock! Not a big town; you probably know him. Last name Smith!
          Brad Johnson,
          '56 Sky Hawk in process
            I lied a little bit.... No #2 in the name.
            I can't find my '53 paint chip sheet to do a side by side, but here is a scan of the '71 dodge truck pine green chip from my old Dupont chip book. You really need to compare these in bright sun to judge the match (which I did) and they are extremely close, as to you need to have the 2 overlapped in the sun to tell them apart, and even then is very subtle.
            Haha. It was 2001. Actually, I went and looked at the can in the garage before I posted that.
            EDIT: Sleeping on the problem helped! Woke up this morning remembering another place I should look for that '53 paint sheet and there it was! Here is a scan of the lombard green chip to compare against the dodge truck pine green above. Scanner settings identical in both scans and no post processing.
            Its a very dark color and does not show well in room lighting. Best seen outdoors in the sun.
            Last edited by Jeff_H; 11-14-2013, 04:43 AM. Reason: Found missing paint chip sheet
            Jeff in ND
              Lombard Green was reintroduced as a 1958 'Scotsman only' color.
                Sunlit picture from 2008.
                Jeff in ND
                  Just got the production order for my 57 scotsman.
                  It came with P5788 Lombard Green.
                  I'm assuming its the same as the 53 color.
                  I wonder how many other green scotsman wagons had this color.
                      WOW! Looking good!
                        Man, that is beautiful. Sure wish you were the one that painted my car 21 years ago.
