Hi gang,
With tens of thousands of threads all over, i'm surprised I can't find what i'm looking for, so with fear for getting beat up, i'm starting a new thread...
I'm changing the rear end in my '51 2R5 from the optional 4.89 to a 3.73 twin traction. 4 speed standard transmission. looking in my parts book, i need to replace the speedometer pinion gear and add an adapter. Looking around on fleabay and other stude parts places, there are stewart warner adapters all over, and all with many different numbers and what not. I have one that will not work, i'm sure. Here's what i'm figuring. going from a 4.89 to a 3.73 means i need to twist my speedometer cable 1.310 times faster than normal. The parts book calls for a 13 tooth pinion rather than a 14, so if I change pinions, i'll now need a 1.217 adapter: neither of which match the one i have, which is 1.0400. SO, I know the 666 SW adapter is an offset adapter, and the 777 SW adapter is straight through, but there are tons of other numbers, V6, T3, T12, R12, no idea what they all mean. Does anybody have a cross reference chart for stude part number 675982 to a Stewart Warner number?
Though the chart in my book doesn't show a 3.73 rear end for the 2R5, the E series does, with the same 4 speed transmission, so the speedometer adapter parts should work just fine. Also, i'll be happy to listen to anybody's advice on my project...
thank you in advance!
c
c
