My 62' wagon has a few gremlins yet to work out behind the dash. I've got the car up and running with dash gages working (less wipers), but the line off the light switch that feeds the lights and other "bulbs" is intermittent on...now off. So I don't have the red "amp" idiot light working. I do have a couple of aftermarket (?) gages, oil (direct pressure line) and the Amp gage. The Amp gage has 2 wires, Red & Black hooked up, then coming through the firewall. How should I connect these 2 wires to achieve amp function ? I am running OEM generator (rebuilt) and a new regulator......
Ammeter Hook up
Tags: None
I have taken the red wire that normally goes to the ignition switch & placed it to the ammeter, then another wire from the opposite side of the meter to the ignition switch.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
Just remember that the ammeter has to be in series with the hot wire coming out of the generator / regulator. The other side is power to the rest of the car, not ground. Power flows through an ammeter . A VOLT meter is totally different in that it measures voltage at a particular point, and one side is grounded. Do not confuse the two or you will short out the hot wire and possibly cause a fire!Bez Auto Alchemy
