I have not yet decided which engine is going in Buttercup, the 259 I'm building now or the '57 Caddy 365 engine.
I have a limited amount of time to spend on Buttercup each day but I am making progress on the 259 build. Yesterday I installed the crank. Plastigaged all journals and all were between .0015 and .002. I'd like to have the clearance down to a little closer to .001, but it is what it is. Today I installed all the rods and pistons. All clearances were the same, .0015 to .002. There again, I had rather have it a little tighter, but this is what I got. I did manage to get all the pistons in the correct holes which is better than the person that built the Packard engine that came out of Buttercup was able to do. <G>
I didn't check how much torque it takes to turn the engine but it does turn free. I have to find an 11/16-16 tap (those things are as rare as hens teeth) to clean the threads in the crankshaft hole and then I'll install the crank bolt and check it. I was getting tired around 6PM so I called it a day.
