Notice anything strange about the gasket. If you can see it in this pic. I had a friend come over to help me with the gasket/window. Goop on the gasket and fit both pane into the opening from the inside, loosening the C channel on the inside helps the fit. Re-install the trim on the inside----but alas- the trim covers the defrost holes on the inside. So out comes the knife. Cut the trim to fit around the defrost. DUH ---I think I know what I need to do, turn the gasket/window around, or spin the glass with the gasket 180 degrees. That's where you guys come in.. Do I buy a new gasket? Or spin the windows/gasket 180 and leave it with the cut gasket on the inside. With gasket trimming on the outside, I can cover the mistake with the reveal molding. I'm to old not to laugh at myself----I have no excuses anymore. Besides the selective hearing quote, I've used them all up.. Thanks
I' ve done some stupid things before, but this one beats all...
Well I'm not an expert but I've done a few Studebaker windshields and all I did the stainless goes in first but they were newer models than yours. Mind you those the windshield go in from the outside so that could be the difference.sigpic
Looking to make my first mistake for this year later today. HA! What I hate is not so much making a mistake, I do that a lot, but making an expensive mistake, or breaking an unobtainium part. (My definition of unobtainium might go so far as "it isn't in my shop", or it's difficult to find, or takes time to obtain when I'm in the middle of a project.)
You may be lucky though, a bit of RTV might fill the holes you cut, and being on the inside they won't do much damage. Be careful when removing the glass though, it's easy to break it or damage the seal. Take a time out first... HA!
(Years ago, I once owned a SAAB 900. The dealers fix for shrinking window seals was to fill the gaps where the butt ends separated with black RTV. As they kept shrinking (up to an inch on the rear side windows), the dealer kept adding more RTV. Strange car, built as if it was the first car ever invented by SAAB, not much like any other car, but everything actually worked very well. But, I digress...)Last edited by Corley; 10-16-2013, 07:56 AM.Corley
The 50 Champions two piece front windshields are supposed to be installed from the inside. When the rubber gasket is on the window, put it up to the body flange inside and pull the rope you have installed in the gasket from outside the car, to pull the gasket over the body flange. (And then there's Rick)I just placed the gasket against the body flange, figuring the inside trim would push the gasket tight against the flange. The outside trim fit pretty neat then. That's why I cut the rubber to uncover the defrost holes on the inside....They are uncovered when the window goes forward over the body flange........The cost isn't so bad......80 bucks from SI......it's the embarrassment of it all. But, I figure, admitting my mistake is part of the cure
