Everything worked great on my last run several weeks ago, and I always disconnect the battery cables after putting the car back in the garage. Today however, the amp gauge just sat there when I cranked it up. Didn't move at all. No charging going on. The engine cranked and ran great.
I had the generator rebuilt and tested several months ago. So what's the problem here? I didn't polarize the regulator after hooking the battery cables back on. But I've not done that in the past and there's never been a problem when I've disconnected the battery and put the leads back on.
Any ideas on troubleshooting on why there's no charging seen at the amp gauge? If I put a digital voltmeter on the generator output terminals, what should be the voltage there? How can you check out the regulator?
Thanks for the help!
