Although the vehicle in question is not a Studebaker, I believe the question (and answers) apply to nearly all old cars, so I am posting it here under Tech Talk. Clark can move it to Stove Huggers if that's more appropriate.
I am replacing nearly all brake components, except for a few short under-hood brake lines, on a 70 Camaro with front discs. Because they are the correct length and pre-bent, I bought a complete stainless steel brake line kit from In-Line Tube. All but one piece fit well. The one that did not fit was replaced by them at no charge, using my old one as a pattern. Here's the problem: a couple of the SS fittings continue to weep a bit of fluid, despite being tightened to the point that I'm afraid I'll strip the threads. The one that is the biggest problem screws into the proportioning valve, which appears to be brass, and presumably is softer than cast iron.
I have heard that the SS brake lines are lot harder and therefore more difficult to get to seal securely. If so, what is the solution to the problem?
