Gentlemen,
OK, now I have a smooth-running Avanti engine as of this morning. It took a few cranks and a primed carb but once she fired she never went back. Powerful ignition and a smooth idle. Lord, it's a beautiful sound. I'll try to record it and post a .wav file.
Then the next weirdness took over.
The steering has locked up.
When I ran the car this morning in the garage, I moved the steering wheel while revving the engine. The wheel immediately started swinging back and forth, right to left, with no input from me. I figure the travel was more than half a turn in each direction. The pump or maybe the pump belt squeaked, not screaming but noticeably. I got control of the wheel and could feel pressure alternating left and right. After a few seconds the spasming in the wheel stopped. I turned off the car.
This afternoon I decided to investigate and move the car. She fired up instantly. When I turned the wheel to get out of the garage something metallic clicked under the car and the steering locked completely. I removed paint and gelcoat from rear quarter panel because the car steered itself against the side of the door. I was able to reverse back in but the damage has been done.
With the engine off I can turn the wheel left and the steering linkage moves left. Going in the opposite direction, I cannot move the steering past straight ahead. It feels as if there is a physical obstruction preventing a right turn. I have jacked up the front end so the tires are off the ground and physically moved the tires. Good to the left, not past straight to the right.
With the engine on, a touch of the steering wheel causes the tires to point about 10 degrees to the right (where I can't go with the engine off) but it locks there and will not turn left or right. Turn the engine off and i can again make a smooth left turn.
There is fluid in the reservoir. The valve was rebuilt by Jon Myer a month ago. no leaks in the ram. I could not find any physical obstruction in the linkage (I was originally thinking a nut or something). There is a slight leak at the bottom of the reservoir.
Up until today the steering has operated freely in both directions with no indication of a problem.
For some reason, this condition is not discussed in the shop manual or in any other publication I've seen. It does not seem to have come up on the forum before either. That said, i figure some of you guys have some thoughts.
Thanks as always,
Tom
Thanks as always,
Tom
