I'm in the throes of installing a Daytona replacement carburetor on my 1962 Lark 6cyl. It's gone pretty well so far, but the Daytona carb has a manual choke rather than the original automatic choke. I picked up a choke cable (http://www.amazon.com/Edelbrock-8013.../dp/B0052EPBX0) at the local Autozone but have not yet installed it, as I have a few questions:
1. Where's the best place to bring the cable through the firewall? I'm thinking I should route it through the existing cable hole that sits above and to the left of the steering column (the one that contains the hood release cable); looks like there's just enough room there.
2. How should I mount the choke knob inside? I'm thinking an L-bracket under the dash would work well, or I could drill a hole and mount it directly in the dash. A third option, the cigarette lighter is broken... if it's not a huge hassle to get it out, I could possible stick the choke knob right there.
3. Do I need any sort of brackets inside the engine compartment between where the cable enters the engine compartment and where it is clamped to the choke?
Thanks in advance!
Thanks in advance!
