I do believe I have an electrical short in my "64 Daytona convertible, and I have spent about 25 hours now unsuccessfully trying to find it, so it's time to seek forum advice. A little background on the car and situation should come first.
Battery discharges itself in about 3 days of non driving. Battery is 1 1/2 years old, and I took it back to O'Reilly's where it was purchased for a load test. They said it was perfect. Then I took it to an auto electric shop that I really trust, and they also said it was perfect. The car is generously equipped with air, pusher fan in front of the condenser with both auto and manual switching, 200R4 overdrive automatic trans,and electric fuel pump. Oh, and I also installed driving lights just before the 2500 mile round trip drive to Colorado Springs. All the above circuits are on relays. Other "add-ons" include an under dash switch to turn on the back-up lights, an Edelbrock AFB clone carb with electric choke, a mechanical stop light switch, and a higher capacity non-stock alternator. I'll admit all this leaves plenty of opportunity for something to go wrong, but my belief, after doing a lot of testing, is that none of the circuitry involved with the above mentioned accessories is the culprit.
My method for finding a short initially involves keeping the positive battery cable connected, whilst disconnecting the negative. I then clamp one end of a test light to the negative battery cable end and touch the pointy end of the tester to the negative battery terminal. If the test light illuminates, that tells me there's a short somewhere.
I have disconnected the alternator. I have disconnected the starter wire from the starter solenoid. I have disconnected wires from the battery cable side of the solenoid, and the only wire that indicates a short is the one that has the 18 gage black horn relay wire mated to the 12 gage red wire that goes from the starter solenoid to the ammeter. When I take off that particular wire combo, my test light no longer lights up. The trouble is, the red wire that goes to the ammeter seems to power a lot of things.
So, I guess my 2 questions for the day are:
1) Is the procedure I am using to find a short correct; and
2) Is there a particular circuit that is normally more prone to shorts than others ??
As always, thank you for whatever advice you can offer.
Larry
Larry
