Over the years I've read all the threads about those that are using an electrolysis bucket/tank to remove rust from parts and always meant to try it. Well, I finally made one to clean up a rusty window regulator and a pair of door hinges. I got my soda ash from a pool supply store and stole a tall 7 gallon bucket from my neighbor. 4 rebar rods, some copper wire and an old battery charger and I was in business. I used the 2 amp setting and just let 'er do its thing for two days (regulator) and another couple days for the hinges. IT WORKS! Removed every speck of rust from the items. All I had to do was brush 'em off, rinse 'em and rattle can a coat of paint...just like you guys said. Really easy AND CHEAP!
Another endorsement for electrolysis tanks
Bob Shaw
Rush City, Minnesota
Tags: None
Sweet, I love it when a Plan works! Looks great Bob.
Soda Ash instead of Arm and Hammer Laundry Super Washing Soda? ...Same thing?StudeRich
Originally posted by StudeRich View PostSweet, I love it when a Plan works! Looks great Bob.
Soda Ash instead of Arm and Hammer Laundry Super Washing Soda? ...Same thing?sigpic
Bob Shaw
I'm curious if anyone was done this process, but not by immersion. Here in California cars often rust from the inside out. The underside of floors will look fine, but water trapped under carpet will rot them from the inside.
Say, for instance, a section of a floor is rusted (but not ruined). If the factory holes were plugged, the soda ash and water solution was filled into the floor depression and the sacrificial iron was insulated from the floor would the process still work? It would sure make for a lot less labor, noise and dust from sandblasting.
Tom'64 Lark Type, powered by '85 Corvette L-98 (carburetor), 700R4, - CASO to the Max.
Originally posted by wittsend View PostI'm curious if anyone was done this process, but not by immersion. Here in California cars often rust from the inside out. The underside of floors will look fine, but water trapped under carpet will rot them from the inside.
Say, for instance, a section of a floor is rusted (but not ruined). If the factory holes were plugged, the soda ash and water solution was filled into the floor depression and the sacrificial iron was insulated from the floor would the process still work? It would sure make for a lot less labor, noise and dust from sandblasting. Tom
No, just putting one electrode in the floor would only clean at that point.
Maybe, try it on a small scale on one side of the car. Problem is, when one gets to the driver's side floor, it's like swiss cheese when new. Waterproofing all the factory holes would be next to impossible, much less the rust holes.
jack vinesPackardV8
