Project Lark 454 - Better MPG??????
In my experience, the words "mpg" and "454" should not be used in the same sentence.
I'm glad I don't have an odometer or I'd be tempted to actual calculate how shamefully low my mpg really is.
Plenty o torque though!
If you add a Gear Vendor OD that might help.Pat Dilling
Olivehurst, CA
Yeah, I'm sure those two fours with non-progressive linkage is going to get great GPM's. I didn't make a mistake, I really did mean gallons per mile. But, just think how much fun it's gonna be when you stomp on the loud pedal.Jerry Forrester
Forrester's Chrome
Douglasville, Georgia
I barrel per cylinder..... maybe we can make all eight work at the same time!!!
Pat, there will be a beefed up 700R4 or a 4L60 Tranny installed so there will be a little overdrive relief.Jamie McLeod
Hope Mills, NC
1963 Lark "Ugly Betty"
1958 Commander "Christine"
1964 Wagonaire "Louise"
1955 Commander Sedan
1964 Champ
1960 Lark
Originally posted by ole 64 View PostNeed to add a trailer hitch so you can tow a fuel trailer.Joe Roberts
Yes, with an OEM short duration camshaft a 1500 RPM cruise can work.
No, absolutely not with an aftermarket longer duration cam. Most all rod builders want the rumpety-rump-big-mutha-thumper idle. The increased overlap doesn't stop fighting itself until about 2,500 RPMs. Trying to cruise a big cam at low RPMs will just be an exercise in frustration.
Maybe, tell us your cam duration and rear gear.
jack vines
Originally posted by t walgamuth View PostHigher gears is the way to get more mpg, assuming your engine is in fine tune. Taller rear end gears and an od tranny is the way to go.PackardV8
Thanks to everyone for your comments on MPG but to be honest I do not care about MPG only how quickly I can go fast.
Also thanks for over 5,000 page views on the blog.Jack White
Charlotte,NC
North Carolina Studebaker Drivers Club
Make sure you buy racing gas also, if your gonna go for more gas use the best. I haven't won a lottery yet so i'm still running a 4 bbl. You wanna be #1 at pushing $$$ through your tail pipe.101st Airborne Div. 326 Engineers Ft Campbell Ky.
