hood spec.
  • hood spec.
    Hey guys, are all the hoods on 55 sedans part number 308084 yfd all the same and if so how many years did they use this hood.Thanks Ryan
    That hood was used for one year. And only for part of that year.
    StudeDave '57
    StudeDave '57
    US Navy (retired)
    SDC Member since 1985
    past President
    Whatcom County Chapter SDC
    San Diego Chapter SDC
    past Vice President
    North Florida Chapter SDC
      Ryan, I just found a supplement no. 1 now I want to say there is two different sedan hoods "first series vs. second series" so the gurus can set Me straight on this.but now I want to know,is the diff. just in the hood to cowl curve or is the width diff. at the back where the hood meets the fenders ? in other words,I'm thinking the ONLY diff. is one fender is pointed upper back and one is rounded upper back ?this should be fun,but just gotta know <G>
      Joseph R. Zeiger
        ok so two part #s it is,Dave would you know what the diff. is between the two hoods ? width /,cowl curve?or both.
        StudeDave '57
        Joseph R. Zeiger
          The difference was based upon the early flat windshield vs. the later wraparound windshield.
          Brad Johnson,
          '56 Sky Hawk in process
            They are different because of the shape of the rear corners.
            The flat (early) windshield hoods come to less of a point in the rear.
            The late (wraparound) windshield hoods come to a sharper point in the rear.
ID:	1683252 Click image for larger version
            It's not too easy to see in the above pictures,
            but the black car is a '54 Land Cruiser,
            and the yellow car is a late '55 Commander.
            The '54's nose is spoken for. The '55's is not.
            StudeDave '57
            StudeDave '57
            US Navy (retired)
            past President
            past Vice President
              Thanks Dave,when you look at both cars would you say one fender would cross to the other by modifying the last 2 inches or so of the upper back corners ? gees now I gotta hope that the inner fenders are the same part #s,I need to hit the book again.
              [ATTACH=CONFIG]26678[/ATTACH] [ATTACH=CONFIG]26679[/ATTACH]
              StudeDave '57
              Joseph R. Zeiger
                Thanks Dave,when you look at both cars would you say one fender would cross to the other by modifying the last 2 inches or so of the upper back corners?
                No, I would not. The same two cars above tell you why~
ID:	1683254 Click image for larger version
                And for kicks- a '54 Champion without a hood or fender~
                StudeDave '57
                StudeDave '57
                US Navy (retired)
                past President
                past Vice President
