Anybody going to the Stude swap meet in Menomonie, WI. next month have a good gas tank that will fit my '61 Hawk? I don't need N.O.S., just a servicable tank for a reasonable price. I can pick it up there or on the way from Fond du Lac, WI. P.M. me Thanks. -Jim
Hawk gas tank
Good examples of those C & K Tanks are not usually what many of us would call "Reasonable", unfortunately as demand goes up and supply goes down, this has to happen.
There should be some still around in the 150 to 200.00 price range when clean and usable.StudeRich
DON'T PITCH YOUR OLD TANK !
I don't care how far gone it is. It is restorable.Brad Johnson,
'56 Sky Hawk in process
And,and,and you ain't near theresigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
I was at the Louisville Street Rod National last week, and one vendor had 15-20 different style gas tanks on display, and many more available by order. I remember thinking, there must surely be one close enough to Stude that could be fitted fairly easy. I wish I'd looked closer, and maybe asked a few questions.
If the issue is crushed or missing one story. If the issue is outlet leaks... I created a fender washer close and two fittings sandwich for an improved mechanical then Solder sealed it. If the issue is pin hole leaks... I'd look at Master Series primer sealer as they claim it will seal pin hole gas tank leaks and having used their products, I'd believe it works. I mistakenly painted clutch pedal bush insert with MS and all the wire brush on grinder wanted to do was polish it. Thought I'd never get it off.
Originally posted by 63t-cab View PostDanny do'nt hold Me to this,but I think a wagon tank is close enough to use.
I believe the tank stampings were the same on Lark, Hawk or station wagons. There was a "boss" at different locations that would be cut out to accept the filler neck depending on the model.Brad Johnson,
