http://www.v8.co.nz/page/2
As we all know, colour can make or break a car, and Trev spent plenty of time with John from Resene Automotive in Hamilton coming up with exactly what he was after. The chassis, inner guards and firewall are all Du Pont Refinish 2K, while the exterior is finished in lacquer of the same brand and colour.
This article is from NZV8 issue 95. Get your copy here.
Engine: 490ci big-block Chev, shaved and smoothed 454 block, four-bolt mains, high-volume oil pump, JP timing chain, Hypereutectic pistons, 10:1 compression, Isky Mega cam, Edelbrock performer heads, 2.19-inch intake valves, 1.88-inch exhaust valves, Edelbrock tunnel-ram, twin Holley carbs, Bosch coil, Bosch leads, Carter fuel pump, 1961 Studebaker fuel tank, custom HPC-coated two-inch headers, three-inch lake pipes, custom radiator, electric fan, Toyota heater, Weiand water pump
Driveline: GM Turbo 400, 2000rpm stall converter, nine-inch diff, 2.7:1 ratio
Suspension: Torana front end, 28mm front sway bar, gas shocks, HQ stub axles, leaf rear springs, two-inch lowering blocks, EB Falcon sway bar, air rear shocks
Brakes: Falcon master cylinder, VH44 booster, Landcruiser vacuum pump, vented discs, Holden HZ calipers, Mitsubishi handbrake lever, 11-inch Ford rear drums
Wheels/tyres:Exterior: Shaved trim, custom body mods, custom tail lights, frenched headlights, extended sills, radiused hood, boot and doors, custom rear fins, narrowed bumper, Du Pont Refinish custom paint
Interior: Full custom trim, custom panels, custom dash, custom seats, HQ Holden steering wheel, Promatic shifter, Smiths gauges, hidden switches, VL Commodore steering column, Sony audio
Chassis:Performance: 500hp ATW at 5000rpm, 800Nm at 2500rpm
Occupation: Restoration and custom car builder
Currently Owned Cars: 1947 Studebaker (chopped, channelled, shortened, sectioned), 1950 Studebaker custom delivery [NZV8 Issue No. 51], 1951 Studebaker Champion (chopped, custom), 1952 Studebaker Commander (Restored), 1953 Studebaker Landcruiser Sedan
Dream Car: This is it!
Trev thanks: Special thanks to Dianne, my ever-patient wife; Greg Knight for the technical info, direction and help; John at Resene Automotive and Light Industrial; Shane and Greg at Mastertrim; Ross and Rob at Forlong and Maisey; Paul at Repco; Paul at Aussie Spares; Noel at Nostalgia Motors; Mark at United Sheetmetal; Peter Delaway; Glen Odlum; John at Pan Pacific; Dion Coombs and Rennie; Paul and Gary at Te Rapa Auto Electrics; George at Paniflow; Justin Smith; Brian at Audio Active
Words: Todd Wylie Photos: Adam Croy
