Hi to all here and thanks for any help and thoughts provided....... Once again I am in a dilemma.
I recently purchased a Unilite electronic distributor and I have had nothing but problems with it from the start.
I had the courage to drive the car (289 Hawk) a little further than around the block and once again it has left me stranded on the side of the road. After walking back home (2 Klm's) and getting the old distributor and all the tools required, I walked back to the car and got started to refit the old distributor. In the dark with a torch.
I started by removing the coil wires, rocker cover and then pulled the troublesome new distributor out.
Then to find top dead centre on number one, I turned the engine by key a few times until striking it lucky and getting it in the correct position.
This was done without a distributor in place.
I then attempted to drop the "old" distributor back into its position and it will not go more than half way in..... any other time it has just fallen all the way into its natural position without prompting. I tried to get to it to go in many times and I have given up (not wonting to cause damage) and therefor car is sleeping on the side of the road tonight away from home.
The gear drive is only just below the surface of the engine block, the first cast ring (dist housing) will not go into the block.
What have I done wrong and is it an easy fix ???
Regards Roger
Regards Roger
