Hello. REALLY need some advise. Am replacing the inner seals (or TRYING to) on the rear axle. What is the breakdown of the differential in relation to the R&R axle for access to the inner seals? How does one get to these / get them out? Thanks to whomever can give me some easy-to-understand instructions (I am not a highly skilled mechanic!!!) Thanks so much! - Chris
1963 Lark v8 - How to Install Inner Seals??? Please help!!!
You have to remove the rear Hub/Drum assembly with a HUB PULLER. then you unbolt the brake backing plate. This will allow you to remove the axle and it's pressed on bearing. The seal is behind the bearing. This would be a good time to repack the rear axle bearings too. Keep all shims in their respective place.
You really need a Studebaker shop manual. It is explained far better than a few sentences.
Bez Auto Alchemy
Wow - I can't thank you enough. You're absolutely right... I need a shop manual. Will have to look for one.
Again - THANK YOU!!!
Chris
Originally posted by bezhawk View PostYou have to remove the rear Hub/Drum assembly with a HUB PULLER. then you unbolt the brake backing plate. This will allow you to remove the axle and it's pressed on bearing. The seal is behind the bearing. This would be a good time to repack the rear axle bearings too. Keep all shims in their respective place.
After the above, to remove the AXLES you install the Drum and Hub assembly on the axle, install the washer and Nut by hand, then slide the drum away from you and "bump" it outward to remove the Bearing Cup (Race) from the housing that is holding the Bearing and axle in.StudeRich
Many many thanks, StudeRich. I really appreciate the response. I am going to go at this tomorrow!!!
Great name, by the way!
Chris
After the above, to remove the AXLES you install the Drum and Hub assembly on the axle, install the washer and Nut by hand, then slide the drum away from you and "bump" it outward to remove the Bearing Cup (Race) from the housing that is holding the Bearing and axle in.[/QUOTE]
axle seals
Originally posted by HissingElf View PostHello. REALLY need some advise. Am replacing the inner seals (or TRYING to) on the rear axle. What is the breakdown of the differential in relation to the R&R axle for access to the inner seals? How does one get to these / get them out? Thanks to whomever can give me some easy-to-understand instructions (I am not a highly skilled mechanic!!!) Thanks so much! - Chris
Originally posted by John L View PostJust wanted to say thanks for this info. I was scratching my head on how to get the axels out of our 64 commander.Cheers,
JOE
"After all is said and done, a hell of a lot more is said than done"
Clark Olmstead
and if you have twin-traction.....
64 GT Hawk (K7)
1970 Avanti (R3)
