Help!! My son and me are working on a 1960 Lark w/ 170 ci flathead w/OD. Runs like a top! I started with the brakes and noticed a disturbing bit of info. It has standard brakes (NO power anything) and the original repair guide list only power brakes. There isn't one section on standard brakes. The actuator/cylinder is mounted on the frame. I found it and noticed the rubber grommet end is cracked. My question is does anyone out there have this issue? Thanks in advance!
1960 Lark 4-door
My '59 Lark VI has standard brakes. I got my master cylinder from Studebaker International. Yes, the master cylinder is mounted under the floorboard. I envy those Stude owners of later years who have the master mounted on the firewall.
Rog'59 Lark VI Regal Hardtop
Smithtown,NY
Might you be talking of the rubber boot that is ribbed looking that is in place to keep out moisture and dirt from the plunger side{input} of the master cylinder. If so. the rebuild kit will include this rubber. Also a new master cylinder is availabe from just about any Stude vendor or auto parts store. A new cylinder will come with the boot. That is my preferred method if you want good safe braking, start with a new master cylinder that should last for years. Get new wheel cylinders while your shopping. jimmijim.sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
Mitchell,
Power brakes were an option. It is not unusual to see non-power brakes on a Studebaker. In fact, I prefer them.Paul
Winston-Salem, NC
Check out my YouTube channel here: https://www.youtube.com/user/r1lark
Tardis; I did a complete brake overhaul on my Model 60S-W6, serial # 60S-59041, that I've owned since May, 1999. Went to my local NAPA dealer, the owner of which is a friend, and with his books, we found everything I needed and at a reasonable cost. Redid the standard brakes in 2004 and haven't had a problem since. They still work well.
Make sure you get a counterman who knows his books. Don't listen to any ol', "That's too old for our books." Too many counter people are lazy or uninformed.
Frank Drumheller
Locust Grove, VA
60S-W6
M16-52 Boyer-bodied fire truck
WARNING! If you're not familiar with these cars you will RUIN the REAR BRAKE DRUMS if you don't use a special puller to remove the drum. It's called a hub puller. A conventional drum puller will not work! The shop manual as well as many other people on this site can explain the procedure to you. Best of luck with the car.
Joesigpic
1962 Daytona
1964 Cruiser
And a few others
