Surfs up everyone, guy's who do this stuff more often than I have mixed up some surf board foam to begin the early beginings of the Larks interior.
Enjoy, Please excuse the cell phone photos.
Custom mold if you will
The Big Blob,
And some initial sanding, while not quite the finished product you can see the direction. The oval is a Dakota Digital controller for
the A/C. not a vent, the vent(s) (crossing fingers) will pull down from the dash just above it
There's some (Neat to me) ideas on the passenger side I'll reveal later on once they get sanded in.
Foam will eventually be covered in fiberglass then removed leaving the shell, you know, to save weight for the Stude drags !
Ha, this (project) car was never designed to be on a strip.
And last. passenger window surrounds, finally tiged together matching the chop.
Also a new panel made for this side matching the driver side. (Removeable for acess I didn't mention that the last time)
I'll have more later. And here they are.
Concept One LS belt system, Anodized clear, Compressor and Alternator are chrome, flash does nothing for them.
Went Anodized instead of polished because upkeep takes too much time.
Sanden s-7 compressor (fittings will be changed to straight and go right through the inner fender)
140-145 amp alternator.
Air Ride Technologies, 5 gallon Air Pod system, with upgraded compressor thats found in many Mercedes, Aston Martins etc
E3 Ride Pro controller with the Electric, Level Pro height sensors.
Level pro compensates for added passengers or weight without having to manually adjust air into shockwaves.
Through the Passenger door looking back towards the back seat.
Slide in battery box.
The Big Blob,
