has anyone out there did this how did they look?
17" torque thrust wheels on a '63 hawk
Tags: None
For me, the look depends as much on the choice of tire aspect ratio as the wheel diameter. The 17" tires are available from 35 to 70. JMHO, but older eyes like to look at older cars with higher aspect ratio tires. I'd think 17" torque thrust with say a 60-series tire would look OK to me. With the rubber band 35-series, not so much.
FWIW, one of our members, sbca96 put 17" Mustang Cobra wheels and tires on his Avanti and I thought the result worked.
jack vinesPackardV8
[QUOTE=PackardV8;749922]For me, the look depends as much on the choice of tire aspect ratio as the wheel diameter. The 17" tires are available from 35 to 70. JMHO, but older eyes like to look at older cars with higher aspect ratio tires. I'd think 17" torque thrust with say a 60-series tire would look OK to me. With the rubber band 35-series, not so much.
I would not have the diameter of the wheel tire setup to be much bigger than OE, I do not like the rubber band look on any car.Mark Riesch
New Bern, NC
Typically, those low profile tires help handling, but hurt ride. I'd stick to something at least 60 or above on aspect ratio, just for ride. Remember, that Stude doens't have the double rubber isolation in the suspension that a modern car would have to absorb the road shocks. Looks, however, are totally subjective, and strictly in the eyes of the beholder.
17" wheels with a 60% aspect ratio tire, makes for a pretty darn big diameter!
Just one old man's opinion, nothing more...Corley
Hey has anyone done the deal with 22" wheels on a Stude! I see some of these in Chattanooga when I am there. Usually 70s/80s Cutlasses, Regals etc. Pretty weird lookDan White
64 R1 GT
64 R2 GT
58 C Cab
57 Broadmoor (Marvin)
Originally posted by Dan White View PostHey has anyone done the deal with 22" wheels on a Stude!
While I can find a local shop to deal with her split rims-
I'd worry on trips that take me very far from home.
I've seen a few Studes with 22.5s, so I might go that route.
StudeDave '57
FWIW, back in the day, I put thousands of miles on heavily loaded trucks with the same 20" split rims. There's no reason those won't take you anywhere and back as long as the wheels aren't rusty and the tires, tubes and flaps are still in good condition.
jack vinesPackardV8
I am amazed when seeing cars on the side of the road with flat tires that are very often these "rubber band" types. So little sidewall for deflection giving a harsher ride & prone to tire/rim failure. They might look "cool" to some & that's their choice but the cost of replacement & all other factors, are not for me. JMHO.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
Originally posted by Warren Webb View PostI am amazed when seeing cars on the side of the road with flat tires that are very often these "rubber band" types. So little sidewall for deflection giving a harsher ride & prone to tire/rim failure. They might look "cool" to some & that's their choice but the cost of replacement & all other factors, are not for me. JMHO.
its a pretty good chance the car on the side of the road has them. That certainly doesn't
mean they are more "prone", it just means that by the sheer number of these cars on the
road the chance is higher.
Up to an 18 inch wheel is 'safe' from bending a rim on a pothole, that is with down to about
a 40 series tire. With a 35 series or lower, your chances go up.
18 inch is also nice on a Studebaker because it will clear the upper front zerk fitting. This
is the area that contacts first when trying to fit 8 inch wide or wider on the front end. I
find that my rim contacts the zerk right on the edge of the inside lip of the wheel. This is
with a 245/45R17 tire on a 17 x 8 inch wheel :
Cruisin by
on the road (older video)
My dad was visiting from Michigan in Mid-2009, we decided to take the Avanti out of the garage and for a drive. My dad drove my Impala SS as the camera car, ...
Tom'63 Avanti R1, '03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, TKO 5-spd, Ported heads w/SST full flow valves.
Originally posted by PackardV8 View PostFWIW, back in the day, I put thousands of miles on heavily loaded trucks with the same 20" split rims. There's no reason those won't take you anywhere and back as long as the wheels aren't rusty and the tires, tubes and flaps are still in good condition. jack vines
StudeDave '57
I personally like 15" wheels. But your Avanti is the exception to the rule. Nice car Tom.
Originally posted by sbca96 View PostWhen you consider that most cars since the late 80s have 50 series or lower profile tires
Cruisin by
TomTom - Bradenton, FL
