I removed the rear axles and repacked the rear bearings on my 63 Avanti. It has a single track and not a Twin Traction rear. I re-installed the same hubs on the axles and everything else as it came out including the same shims on the right side. Now, both rear drums rub the backing plates. Also, there is virtually ZERO end play on the left axle. The right axle end play feels normal. Not sure what went wrong.
Avanti Brake Drums Rubbing After Bearing Repack
Perhaps the cross pin of the spider gears has broken?Bez Auto Alchemy
I don't know how, but both were broken on a twin traction unit I got recently.Bez Auto Alchemy
If you got any type of lube on the tapered axle stub, or the inside of the hub, you may have split the hub when tightening the axle nut.
They are supposed to go together absolutely clean and dry.Bez Auto Alchemy
Its an open rear for sure. Brad, I hear you on the lube. I can't remember if I put anti-seize on or not. It was 4 years ago. I DO know that I hand torqued the nut and did not use an impact. Both sides have this issue. I think it would be unlikely for BOTH hubs to have cracked.
Well...I don't own an Avanti. I also have not spent a ton of time working on rear gears. Most of my vehicles have that little plug you remove...install a grease fitting, give it a shot or two of fresh grease, remove the grease fitting, re-install the plug, and forget about it until it crosses your mind a few years later (or not).
That said...it is obvious that either your drums have moved inward...or your backing plates have moved "outward." Any chance you had those backing plates off and reinstalled them with something out of place that would cause them to move out???
(I know...crazy thought)John Clary
I really appreciate the suggestions from everybody. Thanks!
Its not the brake shoes. You can see where the drum is contacting the backing plate. It is also touching in more than one place which discounts the possibility of two bent axles. Regarding something installed out of place: There isn't much to it. There is a thin paper gasket between the axle flange and the backing plate, or shims on the right side to adjust the end play. BTW, from reading the shop manual it sounds like the shims on the right side provide adjustment for both sides? I mentioned earlier that the left side has NO end play. The right side feels normal. Just trying to get some ideas before taking it apart again to find nothing wrong.
Thanks again for the input!
