I need a couple of the moulding clips for the outside window trim as used on the '55 sedans. They fit inside the moulding and attach with a screw from inside the door edge. The part # is 308474
Also needed is a spare tire mounting "J" bolt. #293705. A shorter one was used on other '55 sedans and may work as well. It is assumed the shorter bolt was used on other sedans due to smaller original tire size.
I could also use a pair of rear brake drums 10 inch smooth. Particularly need a right hand drum.
I am not looking for NOS just functional parts. PM me if you can help.
Thanks, Ben
Thanks, Ben
