Have a 1946 M5 pickup, does the serial# on the door frame and engine # suppose to match?
No! They will never match. Using the Serial number from the seat riser you can obtain the original production order on the vehicle from the Studebaker National Museum. The production order will indicate the engine number that was original to the chassis when it left the line. There will be no numeric correlation.
And, by the way,
WELCOME TO THE FORUM !Last edited by rockne10; 05-13-2013, 05:45 PM.Brad Johnson,
'56 Sky Hawk in process
Thanks, bought this as a 1947, but quickly found out it was a 1946 by serial numbers and serial plate was on door hinge pillar(late 1946 was moved to seat riser) this truck is early 1946, have DMV coming out to check numbers to get title work done, just wanted to make sure the numbers were not suppose to match, they are close, thanks again for the info.
Originally posted by tbirdtbird View PostDoes it work the other way? Can Studebaker National Museum determine the production order and thus yr based on the engine number? Assuming of course the engine has not been changed out.Richard Quinn
