Hello all:
My modified Studebaker has developed a brake problem that I wonder if anyone else has seen. Because my brake peddle started going to the floor after sittng over night, but would pump up and hold steady after a couple of pumps, I suspected a check valve. By process of elimination, I found that the Wilwood 10 lb. residual check valve to the rear drums was not working. When I took the check valve out and inspected it I was shocked! I could see the spring poking through the little "duck billed" rubber check thingy. What could have caused this?
Thanks, Dave
Thanks, Dave
