Just had the power steering unit on the 1962 GT Hawk, 289 rebuilt. Prior to rebuild, unit did not whine, just leaked from somewhere, not sure but fluid level had to be topped off once a week. After the rebuild the unit whines when turning. During the rebuild the mechanic added type A Lucas fluid, before the rebuild I was using type "F" ATF, red in color. The new fluid appears to be green in color. The mechanic used the Lucas as an additional means for stopping the leaks.
What would cause the whining noise and what type of fluid should I be using. The shop manual suggests lubricating the parts during rebuild with type "A" ATF.
WHAT SHOULD I DO???
WHAT SHOULD I DO???
