When I purchased my 51 Champion this summer the temp gauge wasn't working. I opened hood and found the wire disconnected from the sending unit. With wire reconnected & engine on the gauge moves all the way to hot and pegs out, so I left the wire off to protect the gauge. I ordered a new sending unit from a Stude vendor part #530127 for 6 volts because my car has original 6V system. Replaced the sending unit with the new one today and when started the needle on the gauge also pegs out at hot.
Both the old and new sending units (off the block) when tested with a ohm meter with one contact on terminal nut and the other on the threads of the sending unit read about the same resistance of approx. 140 ohms.
Question: Does this mean my gauge is bad?
Thanks
Thanks
