I picked up a rear end out of a 58 hawk yesterday and was checking it over when I found one of the two tags has a "T" stamping on it. Is this an indicator of twin-traction? The other tag showed 3.31 ratio. I pulled the fill plug and it looks like a twin-traction.
Tag on Differential
Yes the "T" is Twin Traction, but the final test was the large Clutch Drum you found right close to the cover leaving no doubt.
If it is still a H.D. Dana 44 for V-8s as it should be, you will see the "44" cast in the lower, right hand Web where the Pumpkin joins the axle Tube.Last edited by StudeRich; 03-15-2013, 10:53 AM.StudeRich
