Is voltage regulator shorted out?
  • Is voltage regulator shorted out?
    I have just purchased a 1960 Lark and the Batt wire was not connected to the voltage regulator. The field and armature wires were connected from the generator. When I tried to cannect the battery wire it just arced as it would if it was a direct short to ground. I believe I had this happen on my corvair and I replaced the regulator which fixed it. How do I test to see if it is shorted out? I would think I should use an ohm meter/continuity tester between the battery terminal and a ground. I'm thinking that I should also check both generator posts to the case.
    Can someone verify what I should do? I don't want to just buy a regulator if that's not the problem because they are about $85.
    Avantidave
    1978 Avanti II
    The Regulator should be isolated from ground, so I would think the issue is in the generator.
      Take the cover off and see if the points are welded together.
      1936 Dictator
      1950 Champion Regal 4 dr parts car
      1953 Commander Regal HT
      1953 2R5 Pickup
      1947 M16 Truck
      1960 Lark VIII Convertible
      1960 Champ 5E7 step side short box
      1962 Champ 7E5 no box
      1962 GT Hawk
      1963 Lark VI 4 dr
      1963 GT Hawk R2
      1964 Daytona Convertible
      1964 Commander Wagonaire
      “America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.” ~ Abraham Lincoln​
