First I just want to Thank everyone who has helped me though the process of getting the Stude back on the road. I do appreciate all the guidance that everyone has given me, and what will be in the future.
I'm glad to say after 25+ years my 1955 President Speedster has come alive. After just a month from digging her out of a storage room where she sat for the last 25+ years. With just a little work and replacing a few things, water pump, valve cover gaskets, heater hoses, battery & cables, ignition wires & spark plugs, oil change, and going through and cleaning all of the grounds and wires pertaining to the ignition she started right up after a little persuading. Coughed a little from the MMO that I put in the cylinders to loosen the pistons and rings, she hit 40 PSI oil pressure right away after starting, really glad that it did considering some of the horror stories I have read on the forum. The exhaust system has some Swiss cheese in the muffler, and in the rear tail pipe so when it kicked over the exhaust was coming from the back and in front of the RR. But the plan will be having a brand new exhaust put in the near future. After about 10 minutes the headers burned off the excess oil that I dropped from the MMO and the other chemicals, the exhaust was blowing clean. I burned about 6 gallons of fuel from a separate fuel container that I had setup, everything sounded really good. When I start it up their really isn't much smoke so I'm confident all the valves are in good condition.
Their is only one concern I have where the filler cap is for the oil their is this steam that comes out from the filler tube? Should I be concerned about it, or is it the old oil still burning off. I plan to build it up to temp a couple more times then will be changing the oil again and adding the ZDDP addictive to the oil.
Thanks again everyone!
Dylan
Dylan
