1955 President coupe, auto shifter on the tree, horn ring and factory turn signal assembly. I need a picture or parts breakdown for the area of the steering wheel. The turn signal switch is installed and is operating correctly. The horn wire correctly activates the horn when I short it to ground. I bent the tabbed locking washer over the wheel nut.
That brings me to the point where I stopped. I have the horn ring, the rubber three-screw spacer, and the plastic inserts for same. I also have a large flat washer. This washer is bent in waves and appears to be intended as some sort of spring? It is large enough that its center hole fits over the steering wheel nut. I'm not sure where this washer is to be placed.
I didn't find a steering wheel assembly breakdown picture in the Studebaker Manual or in the S.I. Catalog. However, Plate 13-4 (type B) in the Studebaker 1955-58 Chasis Manual shows the setup, but not that bent washer.
I wonder if I have all the parts I need for reassembly. Tomorrow I will phone S. International and order a new rubber insert assembly that holds the 3 screws, and the screws. I don't know how to post pictures here. I can send a copy of that manual page via Private Messge if you request one.
Your assistance is appreciated.
C/B
C/B
